nitrous questions
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
i have been freaking out on what to do next lately, SC, turbo, or nitrous.
just some questions i have on some nitrous stuff.
will a 190lph pump and19 lb injectors provide enough fuel for a dry 150 shot??i dont think it will but if not will the 190lph and 24lbers work?
also how do i fool the computer into dumping more fuel in using the dry kits?
will a 150 require a timing retard module? if i need one, how do these hook up exactly. or would it be better to manually retard timing when i am planning on spraying?
thanks for the help
I would think that a 150 shot would be pushing the 19lb injectors past there limit. Just get a wet kit. much safer. As for timing I like my Digital 6 MSD ignition box because it has a timing retard built into it. Otherwise for track use I would just retard my timing 6 degrees for the 150hp shot of juice. Also step sown 1 colder on plugs and gap them to .035.
Dont know what type of kit you plan on buying but I have a Zex dry dry kit that comes with a 75 100 and 125 shot and the nitrous management unit that the selinoid is built into has vacum lines that go to your AFPR and it adjusts your fuel pressure on its own depending on what fuel and nitrous jet you have installed. As far as timing goes it doesn't control any of that just how much fuel is added. I have a 255LPH and 24 LB injectors and I have my AFPR set at 32PSI and I dont need to make any adjustments other than my timing
