this is my daily driver so I need it up asap! my brake pedal got lower and lower over a two week period. The opther day it just went all the way to the floor. After talking to a few people I replaced the b-booster. It was making that pshh sound when I pushed on the brakes. I replaced the booster with another one. it should went away but no brakes. I adjusted the bolt so it would actually push in the master cylinder. still no brakes/all the way to the floor. I've been reading about air in the booster. How do you bleed the booster?
do I Ned to bleed the brakes when I change a booster?
is there anything else I can look for???
It just seemes like there is no pressure there IE: the vacuum is not holding in the booster.
oh! when I pull the vac. line going to the booster I do not here any other sucking from a cracked hose. It looks to be ok as far a vac goes. there is a strong vac.pull going into the booster.
please please help....
