No power above 3500
My setup is
66 289
comp cams Magnum 280 0,512 lift
Twisted wedge heads with trick flow rocker arms 9,8 comp ratio
Performer rpm intake
Holley street avenger 670
Petronix ignitor with matching coil
Is my setup ok?
It has a fairly good low end but over 3500 almost nothing happens. It will easely go to 6000+ but with no power.
What could be wrong?
Need a bit more information. Does the car rev up to redline in neutral? Does it do the same thing in every gear? My first guess is the carb. Are the secondaries opening? New fuel filter? Fuel line size?
first make sure your initial timing is set between 10 and 14 btdc with the vacuum advance disconnected and plugged.
second makesure that your total timing is between 36 and 40 degrees at around 3000 rpm.
the next thing is to make sure you have good fuel pressure, you should have 5-7 psi at the carb, and it should not drop at higher rpm.
once these are set, then we need to determine if you have a rich or lean condition. make a hard run, topping out 1st will do fine, and shut the engine off right away. then pull the plugs(assuming fresh plugs at the start of this test) and check them. if they are black and sooty, then you have a very rich condition, and you need to lean the jets down about 4 sizes to start. if the plugs are white, then richen the jets up about 4 sizes.
after all that, you need to check for restrictions in the exhaust system.
Thanx for all the input.
The timing is set to approx 37 @ 3000
It will rev easely to 6500 in neutral.
And it will go to 6000+ in first and 2nd.Not been able to try it in drive because it's winter here in Norway. But it has no power above 3500 but it will go up to red line.
The car has stock fuel lines and pump.
I have now ordered a 130 gph fuel pump and a pressure regulator,i will also change the fuel line to 3/8.
Should that be enough for my combo?
Kent
All good points above, but I'll throw in a really bad example that I had. Hope it's not what you're going through. I had an engine shop rebuild an engine once. It idled really well, good torque in lower gears (4-speed manual) but just about died in fourth gear on the freeway. It would barely do 40 mph in the slow lane. I checked all the usual, etc. One odd thing was it was dropping oil out of the crankshaft cover. Took it back twice to the shop and they kept saying nothing was wrong. They obviously didn't take it out on a road test. I had a second shop tear the engine down and check. The first shop had installed the wrong size crankshaft bearings! :mad:
Good luck.
Maybe i have an oil pressure issue also:mad:
Because when i have about 2800 revs on the highway my oil pressure is good, but when i increase to about 3000 it will drop to zero.According to the original oil pressure guage. I have thought that it was just a faulty gauge.
I have installed a dakota digital instrument panel some weeks ago,i can check if the same happens with the oil pressure.
When i changed the oil pan on the car a while ago. i took apart one bearing on the chrankshaft,it had some wear on the bearing and crank. I saw that the bearing was 0,30 oversize. Is this the maximum?
