  • 1994 - 1995 Specific Tech
No spark, Ideas?
  • Thread starter Thread starter miller92063
  • Start date Start date Oct 1, 2007
M
miller92063
253
Nebraska
Oct 1, 2007
  • Oct 1, 2007
As i slowed, the car died, middle of a busy F'n street. Got out, checked the normals. Tried restarting, nothing, she cranks fine, but doesn't even try to start.
Checked the spark at the coil, there isn't one. Disconnected the msd ignition, but still didn't work. I got it pulled back to the house and now she sits.
Could it be the distributor? It was making a funny noise that seemed to be coming from that area before the problem, never got around to correcting the noise.
Any other Ideas?
Sirone
63
  • Oct 1, 2007
Try the cap and rotor. Possibly the bearing in the distributor is going bad or seized. Happened to me.
M
miller92063
253
Nebraska
Oct 1, 2007
  • Oct 1, 2007
What did you have to do for the bearing, that is what I am thinking it may be, because of the noise.
Sirone
63
  • Oct 1, 2007
Replace the distributor.
9
95LRGT
12
  • Oct 2, 2007
Guys, listen to the symptoms before mentioning Distributor, he doesnt have spark at the ignition coil, that means the problem lies between the coil and the battery, maybe a solenoid.
Thats my 2 cents.
SQUEEZE&STROKE
SOUTHERN CA
Oct 2, 2007
  • Oct 2, 2007
My brother's 90 GT did the same thing.. It was the PIP? module in the Dizzy. Get a new or reman dizzy and it should fix the problem.
HISSIN50
34
129
Oct 2, 2007
  • Oct 2, 2007
What I would do:
Check for spark.
Check for injector pulsing.
Check your fuses (under the dash and hood).
If you have injector pulsing but not spark, the PIP is ok. Put a test light across the two electrical wires going to the coil. Crank the car and watch for the test light flashing. If it does, the issue is very likely the coil or your coil wire.
If the test light does not flash, ensure you have 12 volts with the key-on going to the positive coil wire (they're labeled). If so, remove the TFI module and have it tested at the parts store. It likely took a dump.
This testing all takes about 10 mins to do. No biggie.
Good luck.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
