No Spark!!
5.Slow93
I can't find a solution anywhere. When I'm starting the car I get no spark except when I let off the key switch. This problem didn't start after I did anything to the car, I did no mods that could have started this. I have replaced all of the following: key switch, tfi module, coil. Still no spark when starting. So I bought an msd system(I was going to anyway) wich includes a Digital 6, tfi blaster coil and pro billit distributor. Wether I have the msd hooked up or not, I get the same problem. These cars don't have a magnetic pick-up do they? BTW it's a 93 5.0 Coupe, incase you couldn't figure that out from my handle.
However, if I turn the key switch on and jump the solinoid with a screw driver, the car gets spark while starting. WTF????
Does the ECM control spark while starting?
Show me the way guys, or this pony's gett'n burned, just 'cause it's piss'n me off.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer
E.) Fuse links in wiring harness
F.) Ignition switch
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing. A Noid light available from Autozone, is one way to test the injector wiring. I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
A.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
B.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
C.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
D.) Firing order off: HO & 351 use a different firing order form the non HO engines.
I read that you did no mods that could have done this.What exactly have you done(anything at all) except replace parts that you thought were bad.Does your battery have a good charge?I started my car yesterday for the fiirst time since december and It was a little weak and did not want to start the car,I had the same thing happening to me (spark after i stopped cranking the motor).I have a msd6al that produces a dense charge through capaciters to the coil and what I was doing was cranking the motor but didn't have enough juice to fire the car over and all that was happening was the discharge of the msd fireing off.I on the other hand have since moved the battery to the trunk,installed a 140 amp alternater,and 10.4 wires but thats all and i had a no spark issue as well it came down to a battery not having a good enough charge we put the jeep to it and jumped it and it started right up.
Well after weeks of trial and error I finally found my problem. I wasn't getting spark when I started the car via the key switch. I checked everything from the wiring harness, coil, solinoid, tfi module, all that crap. It ended up being the actuator for the key switch located on the steering column. This little boogger is what actually signals the computer that you've turned to acc., on or start. I removed the part, opened it up, cleaned all the contacts and BAMM!! She's getting spark when I start. I knew there was nothing wrong with my wires and ignition compenets and finally I found the problem.
I searched for countless hours for problems related to my issue and came up empty handed. I can finally sleep at night. Thanks for your help guys.
