no spout connector 11mpg!/spout questions
85SVOGUY
76
socal
Hi all I recently acquired an 89 gt 5 speed all stock except flowmasters. I did a full tune up and flush of everything, set Tps, timing, base idle, cleaned TB, and maf, sensors etc. I drove about 152 miles and tank was almost empty! So I said wtf?! Come to find out there is no spout connector attached. Would that account for my horrible mileage? I set the timing w spout out engine fully warmed up at 14btdc. What kinda mileage should I be expecting now? Also when I plug in the spout connector is it normal for the timing to jump from the 14 w spout out to around 24?
With the spout connector out the computer can not advance your timeing just like a distributor without vaccume advance. The timeing will advance once the spout connector is plugged in because the EEC is then adjusting the timeing curve it wants to see.
I have heard that a good blade type fuse like the ones on the fuse panel can be substituted for the SPOUT jumper. Just choose any amperage from 5 to 20 amps and you should be OK.
I recommend that after you replace the missing SPOUT jumper that you disconnect the battery negative cable for 5 minutes to clear the computer of any stored codes. Then drive the car for 15-20 minutes at highway speeds and then dump the codes to see if anything else pops up.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
I would imagine that with the timing locked at only 14 degrees with the spout out your mileage would be horrible. And like the others stated it is normal for the timing to be much higher at idle with the spout plugged in.
