Michael Yount said:raph - I thought you were 'outta here'?
Actually I think you got that confused with what I was hoping for
well, i did ride to school on a short bus. oh wait, that was my 'friend'.raph130 said:are you retarded? ........ i would not drive a car if the temp was at 230* all day. thats crazy. as soon as that happens u pull over and check the coolant. if engines didn't have tolerance the first time u run hot it would blow.
The Shape said:I guess he came back just to call HISSIN retarted. Look out HISSIN he may want to meet you out by the monkey bars during recess.
the quote just funny, sorrySilverFox90 said:i mean we are all on her for one reason, we love mustangs and we should really have more respect for one another
i know you meant "here".raph130 said:the stock radiator is fine no matter what age it is. my radiator has over 200k miles on it. my engine runs super cool all day. my last stang had 130k miles on it, it ran extremely well also, and a mustang i had before that had around 120k miles and i never had one cooling problem. i have never encountered a clogged radiator in my life. i have had over 14 cars and every single car had high mileage some with extremely over 180k. clogged radiator can be unclogged with chemicals you can buy at autozone or some hardware store. i am the 3rd owner of my mustang and i spoke with both the 2 owners of my car and i know its entire history.
you are right - water transfers heat ~2.4 times better than antifreeze would.dastang2 said:ok will a car overheat with too much antifreeze, i know it doesn't cool as good as straight water but i know it won't overheat an engine either
so you either run 100% water or 100% antifreeze? im curious (not a bash at all, just curious) why you run 100% antifreeze (in winter i presume). a mix of say 50/50 would likely give you enough freezing protection but would cool a bit better once the motor is warm. i dont understand the reasoning behind the straight antifreeze (i live in the desert also).dastang2 said:well i never have had mixxes, just straight water and antifreeze when the time of year calls and no overheating.
Daggar said:Just plug the hole with a 160* thermostat. It will work better than ever!![]()
HISSIN50 said:so you either run 100% water or 100% antifreeze? im curious (not a bash at all, just curious) why you run 100% antifreeze (in winter i presume). a mix of say 50/50 would likely give you enough freezing protection but would cool a bit better once the motor is warm. i dont understand the reasoning behind the straight antifreeze (i live in the desert also).![]()
Michael Yount said:"the stock radiator is fine no matter what age it is"
Oh my.
