Check out this TSB. They say not to use aftermarket shift stops. Any ideas?
http://www.mustangracing.com/releases/mrtpressrelease2.html
StangLou said:There is already a thread on this topic
If you read this link, even it says the reasoning is so no harm will come from the stops coming loose!
As long as they are installed correctly, there can NOT be ANY damage done to your car from properly set stops!
StangLou said:Yeah, you wont be able to get in either 1st, 3rd, 5th, or 2nd, 4th, Reverse. If a stop is just slightly off, you will notice that its hard to get into a gear, it pops out now and then, or even worse, which you dont want to happen![]()
THANK YOU
