o/r midpipe vs. catted midpipe vs. stock midpipe
I think its time Mr. restrictive stock 4-cat and I go our separate ways, but Im undecided on an aftermarket offroad pipe or catted pipe ;) I live in british columbia, and we have something called "aircare" (aka sniffer test ) every few years, so if I went o/r I would have to keep the stocker and swap it in for smog... this combined with the dreaded "gas smelling clothes" stories I hear is making me consider a catted midpipe instead of an offroad (also, I think an offroad and my flows might be a bit too much sound wise for my daily)
The question: Will I notice SOTP and a real power increase from an aftermarket catted midpipe compared to the stocker? And, does and offroad midpipe yield a lot more power than a performance catted one? Since catted midpipes are quite expensive (compared to offroads) I want to justify my purchase.
i think for the $$$ difference, it's totally worth it to go with the o/r pipe. first, it's much cheaper. second, you'll see a slight hp gain also... ! i didn't notice a SOTP difference, but i'm sure i picked up a couple hp. so why not? just keep the stocker around for the tests! my car was also quieter after my o/r x pipe (but it happened with the LT's at the same time, which probably made the biggest difference).
I personally went the catted X way just because I prefer the sound of a catted exhaust (Which everyone gives me compliments about on my exhaust) and I dread the gas smelling clothes and near passouts from fumes sitting at traffic lights. And I really wanted to stay emmissions legal in case it came back. Mine is very good quality and sounds great and has a great crossover design. I bought it for $280 and it had free shipping. Definite difference in how the car feels up top and I have no regrets.
Exhaust threads ... they can really get out of hand :bang:
if
You don't be specific :Word:
cause
They ALWAYS get around to the ... SOUND ... of things :)
which
We all have to agree ... That is a subjective kind of thing :D
Now ... I went back and read the original post several times ;)
and
His focus of concern is on a performance gain or making more power :banana:
His ONLY mention of sound is a concern of ...Too much of it :chair:
Soooooooo ... Having said all that :)
I won't address ANY of my reply in this post about :nono:
How Good or Bad this pipe or that pipe sounds
and
I won't even get involved with using a H pipe or X pipe :nono:
First ... The OEM 4 cat mid pipe
It is restrictive and on a stocker ...........
the most restrictive part of the entire exhaust system
You can have various degrees of restriction simply because the amount
of miles on it can make it ... more or less ... of a restriction
Second ... A true high flow catted mid pipe
There have just been too many articles using a dyno or the 1/4 mile track
to show the cats make very little difference.
True ... they do offer some restriction but I've seen dyno articles that show
typical NA street car combos will give up 5 rwhp or less with their use.
Common sense would tell us they offer more restriction on PA combos
Third and lastly ... Off Road mid pipes
Most amount of flow
but
Way over rated performance gain by most I've seen on these various boards
Now ... before we see a ton of peeps post up in this thread and say ........
"I notice a BIG gain with my off road mid pipe!" :nice:
We need to remember this fact :Word:
Most of those peeps went from the OEM 4 cat pipe to the OR pipe
and
If the truth be told .............
I'd bet a bunch of those 4 cat pipes were clogged up to some degree ;)
So ........ We need to stay focused on the Q here of ........
The comparison of catted to non catted pipes
The OR pipe issues of ..........
smell
increased db level
etc
They've all been talked about
OR pipes also can cause emissions issues such as ............
Having to swap it out to pass testing
Having to be concerned about being ticketed for their use
I have to tried to stay non biased with any of the three choices :D
or
I did try to ... not give .... my opinion :nono:
My attempt was to ... try to share ... what I've learned about each :)
Grady
I ran the same off road X that you did and my car was about 3 times louder then stock with it. I can't believe that your exhaust actually quieted down by removing the cats.
Mufflers get louder with the more air that goes through them. Less cats, less restriction, more air, more volume.
I wouldn't worry about smelling fumes. Maybe if you are stopped at a red light for 4-5 minutes you'll catch a whiff, but its not like you have to roll down your windows because your eyes water. People that have this problem most likely did not install exhaust components correctly and have a nasty leak underneath the cabin or their tune is off and they are running too rich.
I did the whole "swap on the stocker" thing. If I could do it all over again I would have saved up the extra cake and gone with some high flowing Bassani catted X pipes. My .02.
Adam
if
cause
which
and
and
Most amount of flow
but
and
smell
increased db level
etc
or
Grady
Just the confirmation I was looking for, thanks once again Grady :)
My main concern was that I would spend MORE on the catted pipe, and loose SIGNIFICANT performance over the cheaper offroad one (lets be honest, that would be a big screw. .) Also, I wouldnt want to spend a few hundred bucks, and then not have a noticeable improvement over the stock pipe either :p
Thanks for all your imput everyone
One more thing about running cats :D
There is the issue about running an air supply to them from the air pump
I'm really not sure :scratch:
about all that as in my experience ............
I've run a Shorty and LT catted mid pipe and in both cases .........
I hooked up the air tube from my air pump to them
Now ... If you have done away with your air pump :shrug:
anyway
Seems like I heard someone say some cats needed the air
and
Others do not need it
I just wanted to bring it up and hopefully someone who knows
what they are talking about can enlighten us all on this subject :)
Grady
Grady, you must be a mind reader or something ;) I was actually going to bring up that subject afterwards. I read somewhere that borla highflows (I think it was borla) do not need an air supply. I also read that doing away with the air pump will cause some cats to clog (the stockers at least) thus creating a huge restriction. If anyone can enlighten us on this, that would be much appreciated :)
I havent done away with my pump yet, but it was something I was planning to do during my head/intake install, so Id like to get an answer before I bite the bullet. I want to kill the pump to reduce clutter, free up some weight (marginal, but whatever), free up some power (again, marginal), get rid of the whining pump sound, and stop exhaust popping (the air pump introduces oxygen, thus causing backfires on deccel) Overall, Id just rather not have it in my engine bay, but if my cats are going to foul without it then it can stick around.
