Odd overheating problem
Project 77
370
Bernville PA
I checked my radiator just because I hadn't done so for awhile and noticed it was low, like almost a half a gallon of water low. So i fill it, and since I filled it the temp gauge acts weird, it goes up then down and fluxuats wildly, and when I park it, it pukes all the coolant out.Strange thing is the low coolant light never came on before I checked it but did after I filled it :shrug:
NFG!!
I found the problem...I ran it just now and the temp was spiking then coming back to half then up again. Popped open the hood and the upper rad hose lookied like a waterballoon. New T-stat and upper hose, and I guess I should replace the cap
well....I thought I had the problem fixed. I put new hose and T-stat in now it's leaking like a sieve at the t-stat housing underneath. I took it apart three times and triple checked everything and it still leaks..WTF????
