Odometer & Trip Meter
CueBall
1998 Mustang 3.8L V6
So, trying to trouble shoot this issue, thought I had figured it out.
Bought the car near the beginning of May 2016.
the temp, fuel, battery & oil pressure all work fine in original instrument cluster.
Picked up instrument cluster from a junk yard, but it had a different trace than what is on the original instrument cluster.
Took the 2 instrument cluster's apart and replaced the center speed and rpm section out of the new cluster and installed it in the original casing cluster.
after driving it around for a blocks, the odometer & trip Meter started working for about 1000 miles.
now it has stopped working? could it be a sensor? is there something connected to the transmission or engine?
there are only 2 wiring harnesses going to the instrument cluster.
any help would be appreciated!
Thanks.
I did try a new center piece... so i don't think its the gears are the problem because it has now happened to 2 center pieces.
I have not tried to remove and reinstall it to see if it will start working again.
i just highly doubt that the gears went out on the old center piece and when i replaced the center piece, the new center piece gears went out also.
