Hey Adam, I could use some MM subframes while you're at it! Thanks bro!
looking good man, wish i could do something as extensive as that. After getting engaged and purchasing a DD, the stang will be on the back burner for a good while.
List of the Build:
306 block
keith black flat top pistons(hyper)
wolverine 1190 cam shaft.
10 cut crank.
Stock rods.
Arp rod bolts
TFS KPI street heads (old twisted wedge with inline valves)
3/8 intake spacer
65mm BBK TB
TFS TB elbow
24lb injectors
24lb pro m maf.
FRPP pulley set
comp magnium 1.6 rail type roller rockers
TFS Track heat manifold.
low milage stock t5
low milage ford racing clutch kit.
walbro 190 fuel pump.
all new gaskets
new starter
new rad
new rack
Exhaust:
BBK catted H
BBK shortie headers
Flowmaster 40's
Suspension:
HP blues
Sportlines
other:
New vert top.(yet to be ordered)
New heater core
MM 6 point cage.(yet to be ordered)
Clean up bay:
hide wires
Sand blast
Paint.
how much did the engine work run you, and what kind of numbers are expected?...
Kind of off-topic for this stage of the build, but did you ever get that Word document about how to change a 'vert top yourself? I'm starting to think I want to install my own black cloth top because I'm too cheap (broke) to pay someone to do it. If you do, can you send it to me? That would be awesome.
[email protected]
Shame you live in Montreal, there's a guy in Southern Ontario, between Hamilton & Niagara Falls that I found will do my top install for $400 bucks. From what I've been able to gather this is a job that has to be done right! There is another shop in Stoney Creek Ont but after some checking the guy turned out to be a tad costly! He wanted $750 to install the top!
Well... Moved on to welding yesterday... alll those useless little holes.... chris was welding away all day and i was grinding the welds down... we painted over a few and you could see where it was welded and grinded... any advice on covering the bay with body filler will it hold up???
So will the K-member work with the stock suspension or not?
I'm pretty sure it'll hold up. But, are you considering using body filler to fill the holes instead of welding? I know welding holes takes forever, but it's the right way to do it..
No just so when we paint the engine bay you cant see a little bump or dimple where the welds are. still are rattle canning it. just making it look as good as possible on a budget.
Hmm well, build up the weld enough then get on it with a grinder to make it nice and flat.
OMG sandblasting sucks... my mouth is all scratchy as well as my nose... grosss.... Well the good news is... the bay is gonna look great.... cant wait to get pics posted
They have these things called respirators.....
