Troy- all i ever ran in my car before the heads and cam swap was the mobil 1 0W30 oil, but when I did the cam swap everyone told me to run something thicker so I switched to 5W30. At the time my valves were not adjusted correctly and I had excessive noise so I switched to 20W50, and then back to 10W30 as the heavier weight oil made no difference. Do you have a lot of lifter noise with the 0 weight oil? I only have about 15psi of oil pressure now at idle when the car is warm with the 10W30 so I'm afraid to run anything thinner, but I'd like to gain a few HP by running the 0 weight stuff again.
