oil pressure
My dad's GT does the same thing. When I am stopped it reads at the L in NORMAL. I noticed that the volt gauge does the same, but the fuel and water gauges do not. My 89 LX does the same but with less variation. I don't like the gaudiness of aftermarket gauges but I really want to know what my oil pressure is at.
yep, get a real gauge. you can try a new sender for the oem gauge, but you cant polish a turd.
get a real gauge and know for sure. the stockers are famous for being a little less informative than an idiot light.
while you are at it, get a real temp gauge, at a minimum. the voltmeter seems to be fairly accurate, but the temp gauge is pretty lame.
good luck.
I believe stock idle oil pressure should be like 15 psi for a F.I. 302, had this problem once and it was the stock gauge. The gauge reads in a zone, if you drop below that zone, it drops straight to zero, whether there is really pressure there or not.
