Oil selection
  • Thread starter Thread starter ninety15.0
  • Start date Start date Aug 2, 2005
ninety15.0
1,336
  • Aug 2, 2005
Hey guys i was just wondering what type and weight oil is best with a new motor. Im going to break it in with conventional 10w-40 castrol cause i can get cases for dirt cheap....but i think i wanna switch over to a blend, which brand and weight would you recommend. Street driven car with ocasional trips to the strip...thanks in advance. Oh yea....what tranny fuild works best also...thanks
notchback
1,950
St Clair Shores MI
Aug 2, 2005
  • Aug 2, 2005
full synthetic 15w-50 , not a blend
i like mobil 1 but royal purple,amsoil , are all good
HISSIN50
34
129
Aug 2, 2005
  • Aug 2, 2005
I would be running something thinner in a new mill, unless you specifically had it built loose.
Redline D4 works well in the T5, if desiring a synthetic.
Good luck.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Aug 2, 2005
  • Aug 2, 2005
Broke the cam in with 30 wieght,then got the ring seat and broke in with 20W-50 conventinal.And now am currently running 15W-40 Royal Purple synthic.But I am think about going back to the 20W-50,as the oil pressure (I dont run an oil cooler),was stabile even if the car got up in the temps a little.Once warmed up,the 15W-40 syn. has bout 25-30psi,while the 20W-50 has about 30-40psi for idel and the 20W-50 stays right at about 60psi after 2000 or so rpm's.
T
Service Fluid Recommendations for 2015 Paxton Supercharged GT
  • ThotTrap
  • Aug 25, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 25, 2025
ThotTrap
T
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Suspension A not-so-low lowering spring
  • Justin87
  • Mar 7, 2024
4K
Fox 5.0 Mustang Tech Mar 12, 2024
Justin87
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
