bock said:
how does this thing look like?
i want it!
Home Depot has 2 models available, both of which can be found about half way down
this page.
Another Question -
What is the part number for the pcv screen on a 351w Lightning?
I hope someone can look this up for me, as I am hitting a brick wall with parts stores.
I purchased one for a 302 and the diameter is too large to fit in my intake.
I have done a leakdown test, and
all numbers looked good. All were 3-5% leakdown. This is a fresh motor with Gapless second rings. I have been told that some of theGapless rings require an evac pump to seal properly (but I have not been answered as to why).
I have hooked up a Ford truck pump (it bolted right in), but it pulls far too much vac. Most places say you should have up to 15" at wot/load, and be in the single digits at idle. The first pulley I used gave me nearly 20" at idle, and the smaller pulley gave me about 14" at idle. I have not been able to check the vac at speed/load. I am running the smaller pulley now.
I will put in some kind of restrictor today in an attempt to further limit airflow out of the crankcase. There are commercially available vac limiters (kinda like a blowoff valve in function), but they run a minimum of $60-$70. I know many people have similar problems so I am looking for a low cost alternative to the $500-$1k evacuation kits.
By all accounts these air pumps will burn up fairly quick if large amounts of oil are allowed to pass through them, so I need a very good separator in line before the pump.
I am pushing about a quart of oil a day (less than 50miles) through the pump, but the Home Depot separator is not picking up ANY oil. I have stuck some filter material in the bowl, so maybe it will do better today? If it does well, I may just add several of these in series.
Hissin-
I will Google the Jaz can
thanks
I appreciate all the replies.
Feel free to post any ideas or thoughts, as I could use the help at this point.
Thanks
jason
