Hey guys our local "car guy" weekend is coming in just a few weeks..windsor weekend we call it. Basically a few hundred of us head to a designated track for a weekend of drag racing and other various events. Anyways here's the questions, after installing the Mac upper and lower control arms can I do away with my quads? or should I put new quads on with the new arms??..I was told to drop them, but I figure I would ask.
Second question is..will I find any REAL advantage by removing the front sway bar in my launch??
Third..should I bother replacing the spring insolators on the rear??current ones are a little disfigured..whell more than a little...springs are mac.
Ok final question is more of an Ego manuver...what times should I expect to find with the parts under the hood found in the sig, and out back..new BFG 275/40/17's g-force DR's, mac upper and lowers, mac springs,non adjustable KYG's (new if that matters..though I know it doesn't)...and finally front sway removed...but ONLY if you guys were to recomend it.
OK one more question..aside from the burn out..could someone help me out on best launch technique with the items above in place
Thanks,
Derek.
Thanks,
Derek.
Oh wait, this isn't stock car racing.
. I'm not really upset however because the mph is there. 13.778 @ 105.75 mph with a horrible 2.34 60' time. The traction was fine with the awsome drag radials, I just need more practice launching on them (obviously) I was launching at around 2500 rpm and it would grip, then bog...and stumble as I almost stall the god damn thing, haha. I used a hp calculator on mustangworks.com and based on my mph and race weight (3120 lbs.) I'm making around 287 rwhp....which is pretty good in my opinion. You have slightly ported RPM heads so you might get better mph than me. Can't wait to see your results.
