I got a Predator for my 02 last week.
I got one for my 02 last week, like it so far. I installed the diablo tune, and car acted very different, in a good way.
I purchased it from,
http://www.runninwiththedevil.com, they give free tunes to their customers. I feel it is a very flexiable, easy to use unit. Here is the sales pitch for the predator:
Scott
Current revision for the Predator 1999-2004 Mustang (part no. U7146) is r.42. It is displayed on the main menu of all newer Predators.
1) Predator Applications
The Predator 1999-2004 Mustang (part no. U7146) is applicable for the following vehicles:
V8:
1999-2004 GT 4.6L 2valve
2001 Bullit 4.6L 2valve
2003-2004 Mach 1 4.6L 4valve
1999-2001 Cobra 4.6L 4valve
(2003-2004 Cobra is available in another Predator)
V6:
1999-2003 3.8L
2) What is the Predator?
The Predator for 1999-2004 Mustang (part no. U7146) is a state-of-the art high performance tuning flash programmer, which advances the timing and optimizes the air/fuel ratio. Unlike other 'tuners', DiabloSport’s programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery.
3) Why to get DiabloSport Predator?
The flash tuner that allows for end user adjustability to the performance tune
The flash tuner which accepts custom tunes directly from DiabloSport or from ChipMaster Revolution dealers that you can install yourself
The flash tuner with built-in advanced diagnostic capability that displays fault codes along with descriptions of the code right on the Predator screen
The flash tuner with built-in high speed data logging and monitoring capability that the competition doesn't even have
The flash tuner with a true graphical display that's 300% larger then the competition's puny text only display
The flash tuner running on a custom high performance, multi-threading KROS operating system
4) Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER!
Average power gains are in the 20 HP range. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline.
DiabloSport has generated all dyno tested tunes.
Predator tunes re-map the:
Fuel Curves
Timing Curves
Extend Speed Limiters
Extend Rev Limiters
DiabloSport Performance tunes require the use of Super Unleaded / Premium grade or 91 octane fuel only, like carried by Amoco/BP, Sunoco or Mobil.
5) Adjustable Parameters
The Predator features end user adjustable parameters so the end user can customize his/her tune depending on other modifications done to the vehicle. Because we allow for timing and fuel adjustments the end user can optimize the tune for his/hers specific vehicle utilizing a dyno with proper air fuel monitoring and utilizing the Predators live data feature to monitor timing and other vital parameters.
The Mustang Predator allows the end user to adjust the following parameters:
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
On/Off switch for Traction Control
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
Shift Pressure
RPM Shift Points
Torque Modulation (for better shift feel)
Cooling Fan ON/OFF Temperatures
Rear Oxygen sensor disable (use for off-road vehicles only)
Disable EGR (use for off-road vehicles only)
6) Diagnostics and Live Data Logging
The diagnostic feature allows the end user to scan and erase fault codes as well as monitor live data while driving. Predator can read and erase fault codes, and contains all the Ford specific P codes. Predator diagnostics will work on all 1996-2003 OBDII Ford Mustangs or F-Series Gas vehicles.
Data logging is available as well. With 90 samples per second logging stores 30 minutes of data, with slow rate the logging allows for up to 90 minutes. The log can be viewed in Predator, or it can be uploaded to PC for viewing with the FREE DiabloSport DAT Viewer for Windows software. The diagnostics features can be used on any Ford OBDII vehicle, regardless if the tool has locked itself to a specific vehicle or not.
7) PC Interface Kit
PC Interface Kit allows you to connect your Predator to your PC, and get true Custom Tunes from RWTD, as well as use the DAT Viewer software mentioned above.
8) Custom Tuning
RWTD can do custom tunes for almost any application without the need for end user to send us the Predator. We have PC interface software available for download and the tunes can be sent via e-mails. Please visit our Custom Tuning section for more info.
