Im kinda excited I sold my Paxton SN93 pretty fast...Now i have to place the order for the turbo kit...that will be in 2 weeks gives me time to come up with the extra dough...LOL...Ok i want to run around 8-10 psi...Question..He sells a kit with a Maf that needs the flange welded to the cold side tube . This is what he sent.. Our maf is a Pro-m drop in, calibrated to injectors with our mounting kit. Would that be better to use then the new Abaco DBX 95mm maf...then i would have to cut the cold side and use couplers to join it in...
...Im using gt40 heads 5 angle valve job,stainless steel exhaust valves,Trickflow valve spring upgrade,teflon coated valve seals,1.7 roller rockers, Comp cam 212 int @.050 224 exh @.050 114 center line and 544/544 lift with the 1.7'sTrickflow track heat intake,70mm BBK TB,42lb injectors,255lph fuel pump,aeromotive adjustable FPR, What igniton should i use?..Msd?....What type of Hp do you think i will have?...Do you think i will make more HP then my paxton witht he same mods?
it would give you more reason to find that 351 you've been looking for...then you could really turn up the boost safely!
