First problem is the TA mounting. How you going to do that in a fox chassis?
Second, the springs are in different locations.
Third, we have no measurements on the suspension locations thus who knows if the LCA and shocks will line up in a fox body. Who knows the width of the axle and axle shafts also. It may be so wide or narrow that it is unworkable under the fox body.
Fourth, same issue on the PHB there.
Fifth, who knows what else will cause interferrence issues with that axle on a fox body.
sixth, were you going to mount that swaybar? that is way different than the fox bodies.
On a side note, from the pics I have seen of the brakes they look like Sn95 parts front and rear. Hard to say for sure on the front, but they seems to be also an identical 99+ spindle from the mounting points of everything. that may be interesting! The rear the calipers face forward on the car, but still look like Sn95 cobra parts.
I am sure in time that someone will know for sure or try the swap. But at this point you are not going to find any at a yard!
