I think the rear sits a little high...hopefully it will settle. The front bullets are about an 1" taller than the wheel/tires in the pic. Opinions????
allcarfan said:I think the rear sits a little high...hopefully it will settle. The front bullets are about an 1" taller than the wheel/tires in the pic. Opinions????
dodgestang said:Couple quick questions:
Did you remember not to torque the rear shackels until after you had the full weight on the suspension?
The angle on your underriders is TERRIBLE!! did you install them without the weight on suspension?
What is the outer diamter of your tire...are you still floating around the 26 inch mark or are you down to 24.5?
Are those 5 leaf standard eye?
allcarfan said:Angle of my Caltracs is bad? Thats the ONLY way you can install them. its a straight forward install. No adjusting of angles.
Wondering the same thing. What are you going for here? Right now I got a level ride hight, but I really wanna drop it down about an 1". Nice and low.
allcarfan said:I wonder what kind of performance different it would be to move the pivot point down to the other hole...
Shane
