Ole Yeller is ready for the road
Telewanger
26
I finally have "Ole Yeller" ready for the summer. (1994 Mustang GT) It has been a year and a half project. The man that I bought if from installed the new engine and transmission, then stopped working on it due to the economy. It was in a shed for over two years with well water in the engine and radiator. It messed everything up, but I saved it! Let me know what you think!
YouTube - Mike Lynch - 1994 Mustang GT
I did all labor by myself, but it was a lot of fun.
New timing cover and seal - due to hole in it - $140.00
Thermostat seized up - Replaced Thermostat - $15.00
Radiator full of rust and mud - Replaced Radiator - $150.00
Water Pump clogged and dirty - Replaced - $80.00
Harmonic Balancer - $60.00
Emergency Brake Cable - $50.00
Rack and pinion leak ( bad O rings and sleeve ) Ford and also Mechanic suggested to replace rack- Replaced Rack $125.00
Replaced worn out tie rod ends - $50.00
Power steering pump squealing - Replace Pump - $80.00
Idler pulley squealing - Replaced pulley - $20.00
Leaking power steering hose - Replaced high pressure hose - $40.00
Headers - $ 350.00
Locking aircraft style header bolts - $70.00
Replaced Battery - $60.00
Replaced Fuel Filter $12.00
Replaced smog pump delete - pulley bearing - due to wobble - $10.00
Touch up paint - $20.00
Replaced battery terminals - $15.00
Repaired frayed wiring near battery and other places - $20.00
Balance tires - $25.00
Changed oil and filter - $20.00
Changed Manual Transmission Fluid - $10.00
Changed Differential “Royal Purple” Fluid and seal - $50.00
Flushed cooling system 3 times and replaced Anti-freeze - $25.00
Replaced 3 burned out lights - $ 15.00
Repaired a little rust in trunk area - paint and sanding - $10.00
Repaired holes in H-Pipe - $20.00
Replaced Spark Plugs - $25.00
Replaced windshield wipers - $12.00
Replaced radiator, water pump, hoses and heater core hoses due to splits and cracks - $75.00
Wheel Alignment - $55.00
Replaced power steering pulley - due to wobble - $35.00
looks good, sounds good! congratulations! :nice:
Safety wire on the header bolts....I don't miss that stuff (I was an aircraft engine mechanic, everything is safety wired on an airplane. I don't think my fingerprints would match up due to the scars from getting stabbed by that stuff) :notnice:
Surreal end to your video...its ready to go, yet goes back into the garage...:(
North Carolilna? I miss that state...
Thanks!
I was an aircraft mechanic also. I worked for Flight Systems Inc. in Myrtle Beach, SC. After Sept 11, 01 the company went down the tubes. I got my NC plumbing license, so that's what I do now. I don't miss all of the paperwork and red tape of working on planes. I don't have insurance on the car yet. I just wanted to make a video while the engine is nice and clean. I just got finished with it today.
Thanks!
I called several different insurance companies. I will try to get some insurance tomorrow. I Installed a new steering rack and tie rod ends, so I will need to take it straight to the alignment shop and then for a nice test drive. :D
