Guys i have an 89 5.0 that im trying to turn into ATLEAST a 12 second car. I'd like to be deep into the 12's very close to 11's. Im on an extreme budget and cant figure out which motor route to take:
Stock Stroke 351w
Stock rods w/ arp bolts
10.5 hyper pistons
Stock ported heads w/ upgraded valves + matching cam
single plane intake + carb
Long tube headers
or
Stock stroke 460
10.5:1 hyper pistons
Stock ported heads + matching cam
Long tube headers
Now with the 351 from what i understand it should be a straight forward swap. The only down side is that if i dont go with aftermarket heads then i may end up in the same attainable power range as just building up my healthy 302 and/or being disappointed with the HP when the motor is done.
The 460 i know will give me clost to 400HP depending on my cam, intake and port job. The draw back of the 460 is added weight, the cost of the 460 swap kit.
If it were you, which would you choose and why?
Stock Stroke 351w
10.5 hyper pistons
Long tube headers
or
Stock stroke 460
Long tube headers
