dubbsix,
I just got a reply from two guys that i know for a fact have run 12.50s and faster on these heads, and they both advised .030 off of GT40Ps and said that should put you right around 10:1 compression on stock pistons. Hope that helps.
If you decide to go 351W consider machining it for the factory
hyd roller setup and buying a used set of GT40P already set up
with the right springs.
You can get very good deals that include"P" Headers form Fox-Body
Guys stepping up to Aluminum Heads. There are also alll sorts of deals
to be had on used 5.0/5.8 Hyd Roller Cams. Used Roller Cams are a
whole different issue over used flat tappet. They rarely have bad lobes.
I know these heads get no respect but....
These heads can run anywhere from 13.30 to 11.50 on a 302-311" engine
Thats unported. From stock cam to a full NMRA F/S setup.
Just depends on how well the entire combo is sorted.
They could make a serious torque monster on a 351W with a used F-Cam
especially if the have a little light work by someone who knows what their doing.
A used Stage 2 TFS cam would be even better.
