One tire spinning?
Mikie
the ahead of you horseman
Aug 2, 2000
517
Belmont NC
Ok guys,
My car is doing the one legged burnout and pretty sure that the trac loc needs a rebuild. My question is, am I losing performance with only one tire pulling like that?
Seems I would, but just wanting reassurance to go ahead with the rebuild.
Thanks
Mike
You're going to lose via tire spin. The idea behind having the trac-loc is to eliminate tire spin. Just rebuild it and call it good enough. It's $50 for a rebuild kit IIRC. Pretty easy to do with just a few hand tools.
If you buy extra friction disks, and fiddle with the T-loc shim disks, you can get an extra friction disk on both sides. the t-loc will act funny (hop) when driving in parking lots (tight, slow turns, etc), but it will hold much better. I did it to mine and it worked great. also, when my t-loc failed, the plates didnt just go smooth, the damn thing chewed the tabs off the friction plates and spewed them into my gears... never woulda known had i not taken it all apart when i put the 3.73's in.
Thanks guys,
I will be ordering the kit from Summitt this coming up week and probably plan the install for two weekends out. I know the kit comes with the friction modifier 8 oz bottle, but I have to make sure I get the gear oil also.
I am also in the very near future going to put either Mickeys, or the Nitto DR 275 50 15s on there for added traction. These BFG street tires are a really hard compound and spin like crazy through 4 gears....lol
I rebuilt my t lock in my 93 with the 4 frictions and it hooks up great. Do a search, there are some great threads and websites on how to rebuild the t lock.
And the MTs hook like no tomorrow. But the suck on a wet road.:bang:
http://www.angelfire.com/theforce/5ohcpa/cpa5ohtech018.htm
Very nice website there that walks you right through rebuilding your diff. You can actually just reuse one of the inner friction discs as opposed to buying more if you do the alternate stacking method.
Also, you'll probably find it 100 times easier to actually take the center section out of the car to rebuild as opposed to doing it inside the rear housing.
Also, you will want one bottle of friction modifier to soak the new clutches in (comes with kit) and another to add to your rear diff with the new rear end oil. Also, friction modifier absolutely stinks. Make sure you soak the clutches outside somewhere.
