One wheel peel - need advice
  • Thread starter Thread starter alanw6
  • Start date Start date Mar 10, 2004
alanw6
449
memphis, TN
Mar 10, 2004
  • Mar 10, 2004
Hello,
I figured it would happen eventually, but my stang is now only spinning the right rear tire. An impromptu burnout thanks to some sprinklers the other night alerted me to the problem. I'm assuming my posi is shot. There is a pretty "loose" feeling in the rear end overall.
I've got a 92 with the stock rear end now (99,600 miles), and the axle code shows a 3.08 rear ratio (with a t-5). My motor is mostly stock, except for an s-trim blower and a few related upgrades. I plan to do the H/C/I over the summer, along with mostly bolt-on parts after that. The car is for 98% street duty (non-daily) with a few trips to the track.
What gear ratio is best for 5 speed blower cars? I'm thinking 3.73, but have also seen a lot of supercharged cars running 3.55. Any opinions would be helpful.
Also, what should I do about the worn rear end? Auburn? Stock rebuild? or something else? I will also go to an aluminum driveshaft at the same time since it's a pretty reasonable upgrade.
If more info is needed, just let me know. Thanks in advance for your help.
Alan
88stangmangt
2,332
Stafford,VA
Mar 10, 2004
  • Mar 10, 2004
i am puting in 3.55 with my set-up in my sig and also going with a eaton E-locker you can lock up the rear axles wit a switch for tru posi at the track(or street racing) and then release it with another press of the button summit sells it. but it is almost 700$$$$$ or you could just rebuild you stock trac-lock.
schoonover_88
189
  • Mar 10, 2004
Personally, I would just refresh the thing with 3:75 gears and a traction-lock rebuild and be done with it. It will give you some really nice get up and go, yet will still work with the supercharger. Just my $0.02.
NKau
1,346
Jefferson, WI
Mar 10, 2004
  • Mar 10, 2004
I would opt to just rebuild the stock posi. 3.55's seem to be the choice for most anything with forced induction.
alanw6
449
memphis, TN
Mar 10, 2004
  • Mar 10, 2004
Thanks for the quick replies.
This is definitely not a blank check situation, but I will be able to afford something pretty nice. If stock rebuild is the smart way to go, so be it. Just curious of some options.
My mantra for the mustang since I bought it is:
"When it breaks, replace with better than stock"
Very helpful info so far, anyone else care to weigh in?
Thanks,
Alan
DirtyD916
804
Norcal 916
Mar 10, 2004
  • Mar 10, 2004
i have heard very good things about detroit lockers. might want t olook into them.
TOM89LX50
235
Philadelphia, PA
Mar 10, 2004
  • Mar 10, 2004
I like my Eaton. It performed well this year. Having had 3.08's, 3.73's and 4.10's now, I would go 73's with the blower, no higher. While you are in there you may want to go with larger axles, say 31 spline and top it off with a nice girdle for support. Tom.
5ohjoe87
40
Pittsburgh,PA
Mar 11, 2004
  • Mar 11, 2004
I Would get an eaton posi and some hardend 31 spline axles , aluminium driveshaft and 3.73 gears I Had 3.55 ratio but swaped over to a world class t5z with a 2.95 1st so I switched to 3.73 I Have a powerdyne equipped mustang 11 # boost eatons are rebuildable too..
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Mar 11, 2004
  • Mar 11, 2004
ive heard that trac locks are the best cause the locking and unlocking process is smooth and it dosent clunk around. dont listen to me though i have no car yet.
IMissMy93Fox
143
#10
  • Mar 11, 2004
  • #10
I would say rebuild the stock one with a few extra clutches.. I think i read about having 8 total in there and it working good... I also could have completely made that up, I'll check my back issues when i go home next weekend. As for gears w/ a S/C I would go with 3.55s
89coupex2
18
#11
  • Mar 11, 2004
  • #11
I would rebuild the stock traction loc unit. Use Ford Motorsport part #m4700b should retail for around $50. I went the Auburn route a few years back and ended up wasting about $400 when it was all said and done.
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
