After driving my car all summer, Ive decided that 3.55 is not enough gear for the overdrive. It lugs the motor alot at cruising speeds. So, Im moving to a 9", and which: 3.70, 3.89, or 4.11 would be my most enjoyable choice. Thanks for the input!
Hack said:I had a 5.0 with the factory 2.73s and I thought that was quite good for the street. edit: I should say this was with a stock, fuel injected 1989 5.0 motor. It was super easy to spin the back tires in first and second. At 75-80 in 5th gear, the magnaflows didn't drone bad. Gas mileage on a long highway trip was over 20. At 55 if you want to pass or accelerate you should not be in overdrive. It's great for cruising though, especially on the interstate.
I would go with 3.23 or so if I could pick anything. Otherwise first gear is useless. Now maybe if you're drag racing with slicks you want a different rear gear, but for the street I think 3.23 or so would be perfect.
A 4.10 may sound extremely steep, but because the AOD's 1st gear is so high (numerically low) and 4th gear (overdrive) is steeper than the T-5 it's a very good choice for the driver interested in making their car perform better.
