pypesexhaust said:
Ry, Can you take a picture of the installation and e-mail it to me? there should be no clearance issues on the crossover. Twisting the lh part of the X may solve your problem. The seal at the header may be a little off causing the pipe to sit a little too high. Also consider adjusting your flow tubes. You should never have to cut or bend any of our Mustang crossovers.
i will take a pic the next time i get under the car.
as far as the installation is concerned. the friend i had install it is a professional and owns a shop. i was under the car even helping him out and it is lined up correctly. the manifold seal is tight (we used airtools). when i drove it home, i kept thinking that it's really alot louder than i thought. then i looked under and it had about 1/8" clearance between the pipe and the crossmember. i then took it back to the same shop and we tried to fix it....
when trying to fix it i saw that i could possibly turn the pipe counter-clockwise so that it'll bring the rear section of the pipe downward (even looking at it at level, i saw the driver side pipe was higher than the pass. side). when we loosed both sections of the pipe (between the manifold and the drivers side connection right after the cat) i pulled it down. the problem with that was, when i tried to put the clamp back on the 2 studs on the manifold, the one side would not go on. as much as i tried (well, me and the mechanic) we could not get it on both holes with the pipe positioned lower than before. the only way it would go on the holes is if the pipe was higher up against the floorboard. my buddy then ground down a section of the crossmember. this gave it about 1/4" clearance but it still rattles under load, and unfortunatly its a very loud tapping when it does.
the problem in this case is the measurement of the holes connecting the pipe to the manifood on the left side. if they were about 1/4" wider, then i could've gotten it on both holes with the pipe lower and clearing the crossmember.
any ideas? thank you for reading.
and dont get me wrong. i love the pipe. everything else about it is great and i love the sound. fitment everywhere else was great. but that rattle is driving me nuts though. thanks again, sorry for the long post.
the only pic i have right now (if it's still on my computer) is a picture of the clearance between the pipe and the crossmember.
