Overflow Question.
  • Thread starter Thread starter billison
  • Start date Start date Aug 7, 2016
billison
I like tinted tail
2,607
1,094
184
stl
Aug 7, 2016
  • Aug 7, 2016
using a universal overflow bottle. I have the coolant line ran to the bottom of the tank. The tank has the cheap flip up cap for a lid. Do I need to add a hole for venting or is it fine?
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Aug 7, 2016
  • Aug 7, 2016
Yes, you will need a small vent hole in the top of the bottle
Sent from my big ass iPhone 6 using Tapatalk
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 7, 2016
  • Aug 7, 2016
EBay item
281380958821
I use one looks and works great.
billison
I like tinted tail
2,607
1,094
184
stl
Aug 7, 2016
  • Aug 7, 2016
What's the purpose of having it?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 7, 2016
  • Aug 7, 2016
overflow? You need one because when the engine gets hot the coolant expands and will begin to overflow and if you dont have a recovery tank it will do two things- one piss out coolant all over the ground and then when the motor cools down the coolant actually is sucked back into the radiator. If you dont have the overflow you run the risk of low coolant. in the radiator and overheating
billison
I like tinted tail
2,607
1,094
184
stl
Aug 7, 2016
  • Aug 7, 2016
No, why do I need a vent in the overflow. What difference does it make ? I'm really asking.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 7, 2016
  • Aug 7, 2016
because if the car overheats where is the excess coolant going to go if you dont have a vent tube. It is also to help vent the excess pressure so the radiator or overflow doesnt go boom
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
