Panhard bar problems
I found the joint wore out to fast clunking all the time the ride was no better than stock and often compromised.
I know the installation was right I just don't think it was a benifit on the road.
The stock setup is quite good and will provide a higher level of handeling than most drivers can use.
Dwayne
Dwayne
Man, you mustn't drive hard in the corners then. :shrug:
I beat the CRAP out of mine in the turns and can't imagine going back to a setup without the PHB. Sure, in a straight line you won't notice a difference, but you surely will in the twisties.
+1...I love my PHB, & soon i will have the whole torque arm setup on too. Couldnt imagine going back. Fords rear suspension setup is garbage.
Ok, another update..
I got everything finished and buttoned up around 9pm last night.. Using the dynomax tailpipes it fits like a glove. The tailpipes don't even come close to hitting the PHB.. But - remember, I cut off the dynomax tips and used my old magnaflow ones..
What a huge difference the PHB makes. I got used to correcting the car every time I went hard into a turn. Before the PHB I would turn the wheel and wait for the back end to catch up, then ease up on the wheel before it would oversteer.
Now, it's a smooth turn.. The car turns and that's it.. I don't have to wait for the rear-end to catch up and it's so much more predictable..
All-in-all I give the PHB a 9/10 PITA factor and a 9/10 awesomeness factor..
Riley
I got everything finished and buttoned up around 9pm last night.. Using the dynomax tailpipes it fits like a glove. The tailpipes don't even come close to hitting the PHB.. But - remember, I cut off the dynomax tailpipes and used my old magnaflow ones..
Tailpipes or tips? I thought you said tips?:shrug: I think it was tips??
