Just few days ago I found out that my parking brake cable is tight and holding me back, no wounder I am running slow at the track. How can I make my parking cable loose as possible ? Driver side back was tighter then passenger side cause cable was pulled to the driver side . Long time ago wen i did the burn out at the track my car rearend moved to the left real hard so i am thinking that's why pulled cable
How do you loosen the parking cable? parking brake is very tight and with only 2-3 click it holds rear brake real hard . I am thinking when i launch my car at the track my rear end goes down and then parking brake cable just grabs the brake
Going to the track tomorrow. Just to give you example
I used to run 13.5 with 104mph before cams and now with cams and more rwhp I run 14+sec with only 96-98mph
