PATS Issues on Engine Swap
As far as programming a new key, from what iv'e seen, on this style I would need two keys, I only got one from the previous owner of the parts car
Did you have $30? Did you read all of the information in this thread?
ForScan ODB2 scanner w ELM327 USB
If you know for certain that the PCM, and the cluster and the key came from the same car (IE were married to each other), the ForScan software offers a possible low cost option to DIY key programming. ForScan key re-programming will not work if the PCM-id block do not match (not married).
