Paxton 1220SL
  • Thread starter Thread starter sfcadams
  • Start date Start date Apr 27, 2009
1 of 2 Next Last
sfcadams
56
Tucson, Arizona
Apr 27, 2009
  • Apr 27, 2009
I have a bone-stock 1987 5.0 LX Coupe that I am looking into possibly installing one of the Paxton 1220SL superchargers on. I am not looking for high boost so I thought this supercharger would be a good bet. Here are my questions...
1) Since it has an FMU included, is it necessary to upgrade the injectors or upgrade the fuel pump?
2) Is this kit a pretty much bolt-on and go kit?
Thanks for any and all help!
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Apr 27, 2009
  • Apr 27, 2009
IMO go with injectors and a pump , and have a custom tune made.
FMU's can fubar your engine if the f up.
I think your plan is a good plan
Happy boosting
sfcadams
56
Tucson, Arizona
Apr 27, 2009
  • Apr 27, 2009
Ok, I guess I could always go with the larger injectors and a larger pump in the near future as well. What about installing the kit ust the way it is, i.e. using the FMU? Is it pretty much a bolt on kit?
Thanks!
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Apr 27, 2009
  • Apr 27, 2009
yeah just follow the instructions, I have never done one myself but they seem pretty straight forward
keepinitril
102
Anaheim Hills
Apr 28, 2009
  • Apr 28, 2009
watch out...
ya gotta be careful with your bottom end
YouTube - Supercharged Mustang vs. Corvette
M
Mike in Texas
121
  • Apr 28, 2009
1220 sl
Just installed one in my 1990. Upgrade the fp is a must, I went with a 255 walbro in tank. I stayed with the FMU and it seems to be working fine. Install was pretty straight forward, just take your time. I would also recommend a bypass and an ignition retard, which do not come with the kit. Looking back, the Vortech V3 may be the better deal because you get more boost and the bypass/retard are included.
I bought from superchargers online. They had the lowest price that I could find and the service was excellent.
sfcadams
56
Tucson, Arizona
Apr 28, 2009
  • Apr 28, 2009
Superchargers online told me that I wouldn't need a bypass if I am just running the "stock" 5 - 6 pound boost that the 1220SL makes...
What do you have your timing set at right now?
M
Mike in Texas
121
  • Apr 29, 2009
1220sl
yep bypass not required or the ignition retard. I put on the bypass to help drivability issues and the retard to guard against detonation. My timing is 14* with the sc but my engine is a gt40 crate and fairly modified. I feel OK with 14 because the retard is taking out advance under boost.
One other thing, I'm not sure w speed density but a dyno tune is a must to get the most out of a supercharged MAF car.
R
rwood126
161
mCdONOUGH, GA.
Apr 29, 2009
  • Apr 29, 2009
Paxton's are junk... I had one and it spent more time in the UPS truck going to California and back than it did on my car.
sfcadams
56
Tucson, Arizona
Apr 29, 2009
#10
  • Apr 29, 2009
  • #10
Ok................
Care to elaborate?
sfcadams
56
Tucson, Arizona
Apr 30, 2009
#11
  • Apr 30, 2009
  • #11
I hate when someone will post a comment like something is a piece of junk and then won't take the time to tell us why.....
sfcadams
56
Tucson, Arizona
May 2, 2009
#12
  • May 2, 2009
  • #12
Anybody else have any input on this supercharger?
Mike,
Where did you get your 3.33 supercharger pully from?
BYRDPE
1,556
Memphis,Tn.
May 2, 2009
#13
  • May 2, 2009
  • #13
Mike,
You'll love it.
You can get the 3.33 pulley from superchargersonline.com
Must have been the older model balldrive unit.
Cobra912
1,777
11
39
Wish I was anywhere but here
May 3, 2009
#14
  • May 3, 2009
  • #14
wow
I have a paxton 1220SL on my 331. Paxton does not make junk
I upgraded to 42lb injectors got a tune and ditched the fmu. If you are running a stock car then you'll be fine with it. I would recommend upgrading to a 255lph pump as a must. Under a $100 bucks for a Walboro and easy to change out.
You need a bypass unless you feel like hurting the blower.
I just had my final tune done today. The car with an Anderson powerpipe is only seeing 6lbs at WOT. It obliterates my 275/60 tires half way through third gear.
Time for a pulley!
M
Mike in Texas
121
#15
  • May 4, 2009
  • #15
1220sl
Got the pulley from supercharges online, also usually available on ebay. FYI I believe that the new Paxton and Vortech pulleys are interchangeable.
sfcadams
56
Tucson, Arizona
May 4, 2009
#16
  • May 4, 2009
  • #16
Cobra912,
Do you have a mass-air or speed density engine? I was told since I have a speed density engine that I have to have a bypass valve kit to hook up to the MAP sensor so it will not see boost or something like that. Also, this is probably a dumb question but is the Anderson PowerPipe only for mass-air engines or will it work on my speed density as well?
Cobra912
1,777
11
39
May 4, 2009
#17
  • May 4, 2009
  • #17
sfcadams said:
Cobra912,
I converted my speed density to mass air. So in regards to your question I'm not sure. The powerpipe I'm sure could be used with a speed density system.
Sorry I can't really answer your questions.
I heard people say over abnd over again - convert your car. But I was very hesitant as it seemed very involved. But if you are putting a blower on I would recommend doing the upgrade. All you need is a wiring harness (you can buy a kit) , a mass air meter and a mass air computer like a A9L, A9P, A9S etc
sfcadams
56
Tucson, Arizona
May 10, 2009
#18
  • May 10, 2009
  • #18
Just saw a great deal on one of the Vortech V3 kits. It is a self-lubricated supercharger as well. Based on the fact that I would be adding this to my 1987 non-mass air Mustang, which would you recommend and why?
Vortech V3
or
Paxton 1220SL
Thanks for any and all responses
Cobra912
1,777
11
39
May 10, 2009
#19
  • May 10, 2009
  • #19
I just gave my buddy a ride in my car tonight. Saw 7 lbs of boost on highway at WOT with my 331/ Paxton 1220SL.
NOOOO traction through 1-2 and half way through third. All he could say was "holy S!!!"
sfcadams
56
Tucson, Arizona
May 11, 2009
#20
  • May 11, 2009
  • #20
Ok, found an even better deal on a Paxton 1220SL kit today and pulled the trigger!!
Let the fun begin!
1 of 2 Next Last
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
  • Mindseye007
  • Aug 16, 2026
Mindseye007
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
