Hey I'm having trouble with oil getting sucked up into the Throttle body and intake... I was not having this trouble last year.. this winter I changed intakes from Cobra Upper and lower to Holley SysteMAX setup... I also put a vent on valve cover breather.. in the valve cover I have the baffel... and I got a steeda oil separator that runs between the PCV and the intake.
I have the hose that runs between the Throttle body and valve cover off and those two places pluged off..
What might be causing me the trouble? What could I do? Here are a couple things that I might try...
1. Leak Down Test.....
2. Change the oil to a more heavy weight... I'm running Moble 5w30 Synthetic right now
3. Vent the PCV ?? What can I use and how should I do it?
Thanks for any suggestions and help...
