Decided to finally break down and install the pi cams on the car since I had the next few days with nothing to do (luckily). I'll get straight to the point as the car is currently down and I need to get it back up ASAP!!!
I installed the pi cams with the new bolts as required though am having a problem on the passenger side now. Once we bolted it back up and put the valve cover on, when I cranked it we have some valvetrain clattering. It's clatter like a rocker were to fall off or something similar to that, though thats not the problem as I checked for that
The people around the car said it was coming from the passenger side though it very well could be somewhere else though hopefully I have it pinned down. I torqued the guides to 89 as I believe that is where they need to be, though still have this noise.
I didn't remove the front cover for this install though I am almost positive that we didn't slip a tooth or anything. With the car at TDC, the lobes aren't touching the rockers on #1, which I believe is how it is supposed to be, correct?
Where do I start? I'd love to get this car going soon. Would there be harm in me putting the npi cam in the passenger side with the pi cam in the driver side? I obviously wouldn't run that for a long period of time, though would like to see if maybe its the cam.
As for the noise--definitely a "clatter" and not a knock of any sort. I know this post is rambled on though I spent ~12 hours straight on this car last night and only managed 1 hour of sleep before having to help a friend with some a/c work
I have the cam exposed right now (need to remove 2-3 more bolts off the guides to begin getting it off) and will give it a check. All of the rockers LOOK to be on decent though I will recheck in just a few minutes. I had that problem on the driver side with them wanting to come off and it got frustrating haha.
Will begin tear down on Monday with the timing cover off and buying new chains/guides and having to retime the car. It has 200k miles on it so it really doesn't bother me all that much--though would have rather drove her until she quit rather than starting an install and resulting in this
