  • SN95 4.6L Mustang Tech
pi cams
  • Thread starter Thread starter crazystang05
  • Start date Start date Apr 8, 2005
C
crazystang05
172
  • Apr 8, 2005
Pi cams want to install them in my non pi heads can i do this with out changing spring, and also not takein gthe head off how herd is i have a shop class at school so tools are no problmem same wiht proffesional help thanks
LI98GTStang
1,715
L.I., NY
Apr 8, 2005
  • Apr 8, 2005
Stock springs are fine for PI cams as they aren't too agressive of a cam. I installed PI cams myself - first time inside an engine btw. Just took my time using the long way to install by removing the front cover and accessories to get at the cams. The other method is to buy a cam removal tool from Ford. AFM also sells this tool, but have read that a few guys that have used it said that it's not as well designed as the Ford one. It's job is to relax the chain tensioners while keeping everything in place (keeps the engine in proper timing) so that you can remove the cam gear to take out the old cams and install new. Heads stay in place.
C
crazystang05
172
  • Apr 8, 2005
where did you get your cams, how much of a power gain did you feel, how long did it take you and how much were they. Thanks
T
TGJ
1,049
  • Apr 8, 2005
You can get PI cams new for just under $100.00/piece. With these ones, you need to remove the front cover as these are the pressed-on sprocket.
The other ones new are about $130.00/piece.
PM if you want to know where.
Used you can find them rather cheap. The gains I have seen are about 5 - 20 HP. You will feel the difference especially in the higher RPM's.
I recommend you do it the hard way and remove you front cover. Degree the cams to ensure that they were installed correctly.
LI98GTStang
1,715
L.I., NY
Apr 8, 2005
  • Apr 8, 2005
I got my cams through a Ford dealer and paid if I remember correctly approx $250.00 for a new set although I'm sure you can get them cheaper today. For power I recieved between 10-15rwhp and also some torque gains along with it. As I said, I took my time did it over a weekend with removing the front cover (and accessories) it took me approx. 10 hours start to finish. 5 hours on a Saturday, then 5 hours on Sunday. Putting it together takes much less time than taking it apart. That includes cleanup also.
CanadaStang
2,093
Mb
Apr 8, 2005
  • Apr 8, 2005
I'm thinking you won't see much of a gain unless the do the intake too.
stangman
2,690
10
69
in a 3 bed, 2 bath
Apr 8, 2005
  • Apr 8, 2005
i couldn't agree with this more, although i'm sure many people will disagree with me. but i personally would never do that job again without physically seeing the timing lined up.
as far as getting some PI cams i know MPH www.modularpowerhouse.com has some in their 'garage sale' for 100 shipped
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
