Well I have been watching post after post about the PI head swap..I know the motor and all needs to come out to make the install alot easier...my thinking is..
Wouldn't it be cheaper to purchase a used 99+ 4.6l motor and swap it? I know some of the newer stangs have cois on the plugs instead of coil packs so that may be something that would have to be worked around but what other things should be considered? I just dont see spending all that money and still having a high mileage bottom end and raised compression from the swap..no need to change pistons if you swap the entire motor..
the fuel system is not a problem. you use the PCM and all wiring from your current NPI setup. all you replace is the motor.
