green_fow_six
I did the PI engine swap last year. I would definitely recomend it especially if you have higher miles already on your car. Swapping the motor was a breeze for my mechanic. Saved a lot of labor compared to head swapping. All you reuse is Coil packs, Fuel rails, alternator and tap the temp sensor. I didn't need a tune and with a bunch of bolt ons I dynoed at 260 Hp and 300ftlbs at the wheels. About the same as the higher compression pi head swaps. Also easy to add Long tubes while your engine is out. I just added a supercharger without needing to change the pistons or anything to drop the compression so that will also save you money in the long run if you ever plan on a power adder.
