Picked up some bigs and littles
Alright i got some bigs and littles for my 07 front are 15x3 with tires (got those for 100) and the rears are 15x10 with a 6" backspace, ive read so far that certain things need to be done to make them clear or will they fit at all, im assuming they will hang out of the fender a little bit
Good deal on the fronts! 100$? Good find, I hope you can get the rears to fit :nice:
yeah i did the chandler dance when i got them, the rears im inspecting further, and it appears that the rims are all made the same way, crush fitting in the center and two pieces of aluminum crushed together then welded mounting surface and the exterior surface is identical, completely zeroed and flat on both sides so i think i can safely flip them over and machine a valve stem hole and be good to go
