So the last engine I built I used the crane springs and the crane 2030 cam, it seems like the crane springs aren't really available anymore... back order from summit says the earliest ship date would be June. So which springs do I use? Most people say to turn to the Trick flows but I read about there being problems with the valve stem seals on this thread over at corral GT40P heads - upgraded valve springs?? - Page 4 - Corral Forums.
It seemed like most of the guys were trying to run 1.7 rr's, would that cause the problem? I really dunno or understand the situation so I'm looking for a bit of an explanation if you guys don't mind breaking it down for me.
Also, IIRC, last time I just tossed on the valve springs without actually measuring anything (stupid I know), is there anywhere I can read up on how to properly install the valvtrain components? As far as measuring installed heights and seat pressures... like I said I'm really clueless about all of that
, but seeing how important it is I really want to learn.
