Roush Pics Of My Reichard Racing 3.0 Blower Pulley
00-Saleen
588
Snohomish,WA
Finally Took some Pics today of My Reichard Racing Ultra Grip Non Slip 3.0 Blower Pulley. Pulley Looks Great and Lines up Awesome! Seeing about 10PS! Sometimes 11PSI Depending on conditions, and how hard my foot is Buried into the Gas Pedal :D
As soon as the Money Start rollin back in (Just got back to work.....Boeing Strike) Then its Dyno time!
ag lightning said:
Looks nice! Where did you get that and how much did it set you back?
Check out Reichard Racing's website. They are $150/each.
Website is here. RR might not have it listed on the site, but just tell them which blower you have (Series III, IV, V etc.) and what size you want. They have in stock 3.0" pulleys and will custom make any size you want.
I've heard Chicane's pulleys are made by Reichard Racing, but mine looks nothing like his. The Chicane pulley is $115, and I need to measure mine to see if it is a 2.89" or 2.97" (seems to be a confusion). Chicane won't tell you the size for whatever reason? He just says it is as small as they could make it?
I'm going to assume that the Chicane needs a dedicated puller to remove and install..
Nope, it is as simple as removing the four bolts and removing it by hand. No key or press fit at all. Now this is for the Series IV...I can't vouch for the earlier model blowers (Series III, II, and I).
Awesome! That is much easier then when I had the Heaton on my Lightning. Is that the only pulley that can be modified for boost or do they make a larger crank (assume'n there is a separate crank pulley for the blower).
I'm not sure about other pulleys available like the Lightnings and Cobras have. I know Saleen has underdrive pulleys already on our cars, but don't know enough about them.
Actually, are the underdrive pulleys only on the N/A Saleens or are they also put on the Supercharged cars? Anybody? :shrug:
Got it Directly from Reichard Racing as HazeGray Stated. 150$. 20 minutes to install. Once i Dyno and see the results, then i may be tempted to go even smaller (2.8). And the Underdrive pulleys are only for the N/A Saleens. The saleen superchargers run off of the Crank, as the Lightnings and Cobras ( as u probly already know) have a seperate System. A Smaller Crank pulley has shown an increase in boost though on a Series IV.
AG Lightning, are you currently, or looking into getting a Series IV Supercharged Saleen?
I've already located one and am looking to pick it up next Friday. The owner has already installed the IV and a 255 fuel pump. The big stuff is already done so now all I have to do is work my magic :)
Got 487rwhp on the Lightning, let's see what we can get out of these Saleens :)
