Pilot Bearing OR Bushing
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
I got a long time gear head friend who has a boy with a Fox notch.
The boy drives the little notch kinda hard which is certainly no surprise to me and my friend.:rlaugh:
The t-5 in his notch has been rebuilt 3 or 4 times now. :bang:
My friend was talking to a guy at a local trans shop and was told to ditch the bearing and go with a bushing. He said the bushing would hold up to the abuse much better than the bearing. :shrug:
That was over a year ago and the boy is still on the same rebuild. :eek:
Just thought I'd share that with everybody. :D
Grady
I guess I hadnt known of any real known reason with pilot bearings failing. Do they?
I always considered bearings better than bushings. My early cars had bushings and I guess they werent as solid tight as a bearing, but maybe they were not as likely to fail completely like a bearing could. :shrug:
I have known of pilot bearings seizing and that aint too good if you are sitting at a red light behind a car.
I don't know if the bearing would be considered to be more weak than a bushing J T.
Just something I heard and thought I would pass it on.
Grady
FWIW, I asked my buddy about it - he does R&D prototypes of seals and bearings and such for a huge manufacturer, and is a genius with this stuff. :hail2: (Grady, you'd like his showcar '67 FB with a 428 CJ, 390 PI heads, etc).
Anyhow, he said (from my recollection, so let's see if I get it right) that there might have been an indexing issue with the centerline (indexing), and the stress was tearing the bearing up. But a bushing, being simpler, might have been able to deal with the additional stress of the indexing issues.
This sounded pretty reasonable to me.
Just info.
Green 94 5.0 said:
i havent ever heard of a pilot bearing going bad. but then again, the way the bearing looks and the way the input shaft enters it, i could easily see a failure occuring if the input shaft wasnt going in perfectly straight.
Thats what i was thinkin too
hummmmmmm i just installed a new clutch about 3 days ago.... i had the option of putting in a new pilot bearing or a new brass bushing.... i went witht the bearing....now i am second guessing my decision.......
