MSD Wires
NGK Plugs
MSD Cap And Rotor
Aeromotive Fuel Regulator
255lph Fuel Pump
Fuel pressure is set a touch high at 42 right now.
Timing Is set to 10*.. so unless it jumped a tooth....
Vacuum is right around 17-18 if i remember right. And Im in Yuba city, CA.. so i think pretty close to sea level.
And cleaned every sensor and valve from the intake to the mass air meter.
The car will drive great, accelerate hard and drive like a beast. Then 10sec later, when i get on it, will ping like crazy. There is just no telling when it will do it.
My chilton says there is only a couple things left that can cause pinging
Timing advance malfunction, or EGR. But i thought id ask since you guys have had 94-95's longer then me. PLEASE HELP... THANKS IN ADVANCE!
