Please Help! 2.3L Won't run!
Ok, I have been fighting with this thing for a while! Someone please give me your imput! The car is a 1993 2.3L Mustang. N/a 5spd.
The car was running fine. I parked it for a while (4-5 monthes). The car started and ran for 10 mins, then died. Then I started it again, ran for 10 seconds and died. That was the last time it ran. The car cranks over great but doesn't run!
I have since replaced the battery, DIS, fuel pump and have tried different combinations of coil packs (picked up a bunch at the wrecker). I took off a spark plug and there was no arc to the engine block. I pushed the shraeder valve and there seems to be fuel pressure at the motor.
Is there any fusable links that could have been broken?? How can I test the volage going to the coils (there is 3 wires, which ones do I test?)? Could every single plug be fowled to the point where it wouldn't start? Could all 4 injectors could have gotten plugged up??
Any input would be great!
