When I bought this car in '97, I thought it had a heavy duty clutch from the previous owner, as it was really hard to push in the clutch. Ran it that way until last Oct. when I burnt up that clutch. No biggie, it lasted quite a few years under my ownership. I was amazed at the fact that I seemed to be taking out a stock looking clutch, when it did not fell like a stock pedal. Oh, well, I replaced it with a Spec Stage 2. Everything was fine initially, pedal effort was nice and light, thought I was in good shape. Then during the 500 mile break in preiod, I thought I felt the pedal getting harder to push in. I immediatly thought stock plastic quad. trouble. I ordered a UPR triple hook quad. w/FWA. I put that in this spring. Since then, it has never felt right, but all of the adj. were done properly.
Well I had a set of 3:73's installed today, and I tried it out, and the clutch started to slip. WTF!!!!!!!!!!!!
This clutch has less than 3000 miles on it. I barely drive my car. What is the deal. The only thing that I did not change with all of this was the clutch cable. It seemed fine, no snags or any other deformations. Any ideas as to what the problem is?
I thought I was having clutch issues until I replaced the cable... a bad cable can cause a lot of problems as well as heavy pressure on the pedal.
