  • Digital Self-tuning Forum
Please Help! Datalog Uploaded Hanging Idle
  • Thread starter Thread starter OneSick99GT
  • Start date Start date May 25, 2019
  • Tags Tags
    datalog hanging rpms high idle sct software tunign file
First Prev 2 of 2
stanglx2002
CT Material here
1,563
1,110
164
May 30, 2019
#21
  • May 30, 2019
  • #21
The software looked very familiar to TurnerPro RT software that I used with the Moates Chip I had on my stock ECU before upgrading to a Megasquirt.
OneSick99GT
364
46
38
Dayton, Ohio
Jun 1, 2019
#22
  • Jun 1, 2019
  • #22
@a91what BTW I bought 47 lb ford injectors. I'm replacing when I come and we will go from there. I had a professional tune shop I emailed my datalog to respond back saying one of my injectors are stuck open or not working since I have a fuel trim issue. I needed to replace them anyways like you and I discussed. Im also replacing the spark plugs at same time. So hopefully this will correct any mechanical issues I have and we can get backt o dialing in the tune. I'll post here once everything is done and I get the tune close.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jun 1, 2019
#23
  • Jun 1, 2019
  • #23
Ok, when you get the plugs out arrange them in order and take a picture of the porcelain.
OneSick99GT
364
46
38
Dayton, Ohio
Jun 1, 2019
#24
  • Jun 1, 2019
  • #24
I'll have them out in a couple days. I don't have the tool required to pull them. My dad is going to help since I have aluminum heads. I don't want to break them and he has experience pulling them so I'll watch him do it and if one breaks he has the tools to remove a broken plug anyhow so. Ill arrange them in the order they were on my heads and take a picture and post here.
OneSick99GT
364
46
38
Dayton, Ohio
Jun 8, 2019
#25
  • Jun 8, 2019
  • #25
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jun 8, 2019
#26
  • Jun 8, 2019
  • #26
New injectors?
OneSick99GT
364
46
38
Dayton, Ohio
Jun 8, 2019
#27
  • Jun 8, 2019
  • #27
@a91what Everything is almost ready. I had to buy adapter to work with my new fuel injectors. They will be here Sunday. For now I tried updating the injector tables. Take a look Steven and let me know if it looks right. I uploaded the pictures so you can see them.
OneSick99GT
364
46
38
Dayton, Ohio
Jun 8, 2019
#28
  • Jun 8, 2019
  • #28
I also have my plugs arranged for you. I'll get a picture uploaded here soon but they look fine and consistent across the board. Once the adapters arrive I'm plug in and start. I just hope the injector tables are correct. They are 47lb ford racing.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jun 8, 2019
#29
  • Jun 8, 2019
  • #29
Where did you get this data from?? Are these the LU47 injectors? if so i use this document.
https://performanceparts.ford.com/parts/ics/m-9593-lu47.pdf
OneSick99GT
364
46
38
Dayton, Ohio
Jun 9, 2019
#30
  • Jun 9, 2019
  • #30
@a91what Yes! I plugged in the numbers from the ford performance tables I found on the website. That's the exact table I used. It wont let me change the top or bottom row as its locked in the tables. So that is what I have. I believe I did everything correctly.
OneSick99GT
364
46
38
Dayton, Ohio
Jul 2, 2019
#31
  • Jul 2, 2019
  • #31
@a91what I uploaded a new tune from files I received with the software for my maf and my injectors. Once I did that the car runs like out of a factory now. She runs awesome. I've never had her run this good since Ive owned her. That's 7 years. I have 1 issue now. It bucks under extreme load when going from 1 to 2 gear. It also does it when going from 2nd to 3rd gear and 3rd gear to 4th gear. It happens right when you shift up and drop the clutch it launches for a second then bucks then goes through the rest of the rpm just fine. I took a datalog of it so we can figure it out. The log Im attaching shows it doing it 5 or 6 times in the matter of 10 minutes of me driving it hard.
Let me know what you think from the datalog
  • Datalog Under Throttle 2 First test.zip
Decipha
221
36
39
New Orleans, LA
Jul 27, 2019
#32
  • Jul 27, 2019
  • #32
but your isc transfer function back how it was
dashpot is what controls rpm during decel
if its hanging rpms during shifts you kick up the dashpot decay rate up top
i have a write up on my website
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 27, 2019
#33
  • Jul 27, 2019
  • #33
@Decipha if I tag you in the questions on the stock stuff and you pop in that would be awesome. I know my way around the stand alone stuff.. the stock ecu not so much...
OneSick99GT
364
46
38
Dayton, Ohio
Jul 27, 2019
#34
  • Jul 27, 2019
  • #34
Oddly enough it was a small tune issue. It was leaning out under extreme load in a very small area of the table. I fixed it and added fuel to that spot. Bucking went away. The PCM couldn't make enough adjustment to compensate for it quickly enough so richening it up cured the issue. Thanks for the help!
Decipha
221
36
39
New Orleans, LA
Aug 9, 2019
#35
  • Aug 9, 2019
  • #35
yea no prob i dont frequent too often tho
First Prev 2 of 2
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
F
Need help with Microsquirt idle
  • FirstFox93
  • Mar 8, 2024
2K
Digital Self-tuning Forum Mar 12, 2024
86HO5.0
L
Drivetrain 2000 GT High Idle - Pulling Out Hair - Help
  • lleonard1185
  • Jan 18, 2025
SN95 4.6L Mustang Tech Jun 4, 2025
Leo090
L
