wow now your talkin out of my league. This was all done with the hazard switch off.
Ok I went outside and made some better connections and I have power at the Orange wire with yellow stripe. I followed your steps. There is power at fuse and at the relay, there is power up at the hazard in the blue wire and as well as the orange wire with yellow strip, there is also power to the back of the turn switch at the orange/yellow wire. What should I look for next. To me it sounds like all is getting power, am i missing somethign obvious?
Can the ignition switch, mentioned in this thread http://forums.stangnet.com/showthread.php?t=710917,
cause the turn signals to not work? I didn't see it in the diagram.
cjones, thanks for continuing to help, hopefully kdubs is getting info as well. Do I check the MFS O/Y at the hazzard switch or pull the connector off the MSF? I have the column closed up right now, so it may be Thursday before I get a chance to open it back up.
Thanks again, Vann
