Every since i did the t5 swap 2 years ago I havent had blinkers on my car, I took the speedo cluster out to re route the speedo cable when doing the t5 swap, and the pigatils on the back of the hazard switch were so brittle they both cracked so i didnt have rear defrost, hazards or blinkers for 2 years now. Thanks to a fellow stangnetter who hooked me up with new pigtails I now have hazards and rear defrost but still no blinkers. Im stumped on where to look, its very possible while doing the t5 swap and lowering the steering column out of the way that some of the wire may have been holding the steering column up on there own, this may be the problem but i have no idea which wire to check for or anything. The blinker/windshield/high beam switch is relativley new about 3 years old, and the high beams still come on which i assume means the switch is ok, im not sure about wipers cause my car doesnt have them. Because the high beams work on the switch does that rule out a bad turn signal switch?? I dunno what would you guys look for 1st?
