So the master cylinder went in my 85GT and I swapped it out. I didn't bench blead it, but I have bled the brakes twice as the problem continues. The brake peddle is hard and the light on the console shows I have no brake lights (which I have confirmed) so what is happening? Everything worked (aside from the peddle going to the floor) before I swapped out the MC. I was told I may need to adjust the pushrod, but wanted to confirm before I do anything else that makes the issue worse. Thank you for the help in advance!
