Okay, let me just say that the only part of the car that I dislike working on and the only part that gives me any problems is the darned cooling system. Primarily coolant related areas.
I decided today that I was going to put a 180 tstat in my car. Easy enuf and only $10 or so. I had a few hours to kill so i went ahead and drained all of my coolant and unbolted the tstat housing. Come to find out, after all that, the previous owners had already installed a 180 tstat.
Now, my problem is, and typically is whenever I install a tstat...I cant seem to get the car to get all the air out or something. I installed that thing twice today. Both times the tstat was put in correctly with the spring in the manifold, gasket and plenty of silicone. The tstat did not 'fall' down inside of the housing cuz i checked it and it was perfectly centered. I did burp the radiator by squeezing the top radiator hose, several times. I started the car with the radiator cap off as well to let it burp itself a bit and continued to squeeze the hose till no more air bubbles came out.
Still I couldnt get any heat inside of the car, the upper hose never got real hot, the coolant boiled over the radiator and the car began to excessibly heat up.
Whats the deal here? I'm tired of cleaning up coolant from the garage floor and I want my car to run. I hate coolant, I hate tstats and I hate radiators!!!!
